force 120 wiring - main fuse
abbotm5
Im not sure where the main fuse gets wired to. I used the old broken wire harness from the 90 just to set up for testing before soldering. All the wires from the boat were used, and the only red wire was coming from the top of the block. So from process of elimination and color matching I hooked them together. That blew the main fuse and the fuse for the tilit and trim (as I found out last night) since it had a jumper for some reason on the old harness. In the picture you can see two red wires connected at the harness. That connection is not right and I would like to figure out where the main fuse wire should go and also where and what the other red wire is?
