1990_Bayliner
Thread starter- Joined
- Aug 19, 2010
- 33
I had this boat for about 4 months now and it ran like a champ until I started experienceing starting problems. I do not use the boat these days so I try to start it every 2 weeks and run it at home with water hooked up to the engine for 5-10 min. Last time I started it, it had hard time starting and I ran the boat for 5 minutes shut it off. Two weeks went by and now I tried to start the boat nothing..... after multiple attempts and choke I believe I flooded the engine. So i took the plugs out dried them off.... tried again.... nothing. I took both of the carbs off and sprayed carb cleaner through the ports, flushed the carbs and inspected the floats etc... I cleaned the fuel filter and put everything back to gether and squeezed some fuel into the engine then tried to start ....and nothing. I do not know what else to do I troubleshooted the fuel and nothing. Is there anything else I can try? Thanx for you help!
1990_Bayliner
1990_Bayliner
