Hello to you all from cold finland. Posted a topic a few months a go with the subject "oily water" Many thanks to Force01 & the marine doctor for answers. So, now my problems are following:<br /><br />Changed sparkplugs at the end of the season and drove with them for about 3 hours. I checked the spark plugs on the engine and two plugs were as they have never been used and two of the plugs were a bit black, kind of dirty. What might be the reason for this?<br /><br />I also have a trim problem, seems to leak from the chamber of "drive trim", the bigger cylinder. the tilt and trim work allright. The o-ring at the bottom of the chamber has been changed, but it didnt do the trick. Is there any possibility to seal the cylinder from outside with some sealant? Chamber is a bit worn out, new one costs about 350E in finland = about 370 us dollars. I need a good adwise from you guys, thats a lot of money for an old engine..<br /><br />One more thing, last time i wrote here force01 answered me that my engine might have a cloggeg or defective puddling system. I dont understand what is puddling system.
Could you please explain me more, whre is this system located?<br /><br />Thank you for your answers, Jaba
