I just got done replacing the water pump from my 1995 Force 120 and now I can't go into reverse! Is there something that could have gotten out of alignment during the process of removing and reinstalling the lower unit? Symptoms: motor is engaged in forward gear while gear shift lever is in the neutral position, motor won't go into reverse (or neutral). Throttle is engaged when moving the shift lever into reverse, but not enough lower rod movement to engage reverse. I disengaged the upper gear shift rod from the lower rod and am able to manually get the motor to transition from neutral to reverse and from neutral to forward by moving the lower rod, but the upper rod is adjusted such that the required travel to engage reverse won't be achieved. I'm thinking I just need to adjust the upper rod position to allow the required travel, but I can't figure out what in the world would have caused this to get out of adjustment in the first place since everything was working fine before I removed the lower unit. Any thoughts?
