Force 125 88’ won’t run
Oillywater
Hey guys I’m new to all this, even owning a boat. And I just picked up a bay liner capri with a 125 force 88’ and I couldn’t get the motor to run just crank I disconnected the magneto like and the motor started puttering. Then it kicked on for a bit shut it down then tried again and it ran for about 5-10 seconds and it made a big pop and shut down and I noticed it also shot out a lot of oil into the bucket of water I had it in. from the exhaust I think. And now I can’t get it to even putter. What should I do. What does the oil in the water mean? Please help. IMG_0991.jpeg
Oillywater
Sounds like it’s not getting gas cuz before when I’d shut it off I’d have some gas drip out the carbs or even when trying to start. Now nothing.
Edit- I started it with some starter fluid and it only stays on for a moment and some times backfires. Could it be carbs?
jerryjerry05
Don't make it backfire!!! This can cause way more problems than you can imagine.
FIRST: do a compression and spark test, post the results??
How is the fuel system set up? Portable tank? built in tank? How did you mix the gas/oil?
Pull the plugs and compare them then post a pic of them in order #1 top to #4 on bottom.
Second: clean the carbs, post the condition??
Do these things and post the results.
Oillywater
Right now I have it set up to a portable can of gas 2.5 gallon and I have the mix a 50:1. The plugs are new but the old ones did have some black stuff on them I pulled the carbs to clean them everything was pretty clean besides the gas being old so I sprayed carb cleaner all over it and thru the ports. I have spark. But I haven’t done a compression test yet
Oillywater
Here’s the sparks sorry I don’t remember what order they were in since I changed them yesterday also don’t remember if I tried cleaning them hahaimage.jpg
Oillywater
This is top carb second one looks identical condition wise and just don’t have pics of second oneimage.jpgimage.jpg
Oillywater
tg3690
A 2-stroke doesn't have engine oil like a 4-stroke. The lubricating oil is mixed in the gas at 50:1 ratio. So there is no engine oil drain or filter on a 2-stroke. Have you run it without adding oil to the gas?
Oillywater
I added oil to gas but that’s about all I know for 2 strokes I just wanted to make sure so I could change it. My first 2 stroke. And first boat so big learning curve but I know my cars.
tg3690
Good.....so don't worry about changing the oil. Lol Btw....that first pic of the oily water.....kinda normal for an old 2-stroke.
Oillywater
Nice ok thanks. Now to figure out why it doesn’t wanna stay on haha.
For compression
#1-150psi
#2-145psi
#3-145psi
#4-145psi
tg3690
For compression
#1-150psi
#2-145psi
#3-145psi
#4-145psi
Good compression.....do the spark test next like jerry said. The water in your bucket in that first pic was extra oily because the engine would not start, and the unburned fuel and oil had to go somewhere....if it was running a lot of it would have burned off and become smoke....
Oillywater
How do I do a spark test? I have a spark plug tester that I can see lights up when I crank it
jerryjerry05
If it lights up on each plug?? then you have spark.
That broken gasket: I wouldn't worry about it right now, it's probably not all the way through and just the corner.
The part: called a Dog Bone. It's part of the fuel recirculation system.
Take it apart, it has reed valves and screens to catch the small bits of carbon , yours is probably clogged by now??
Maybe change the gasket in the future. You can find the screens in any store that sells smoking accessories.
Oillywater
Ok I’ll prob wait to open it up unless I need to for it to run cuz I don’t have the gasket and I have a feeling if i open it it will not be good anymore
Oillywater
Could I use gasket maker like rtv for stuff like that. Also I’m changing the water pump and when I was removing the 6 bolts they had a lot of silicone on it could I just use Anti seize or does it have to be silicone. Also noticed at the splines where it goes into the engine there’s some gunk on them looks similar to the soot in the water should I be worried about this. Or could it be the gas that was leaking from my carb and down to the lower unit?
tg3690
If you plan on keeping and using this motor it would be a good idea to get a factory service manual.....several listed on ebay......worth the money and will answer most of the questions you are asking. This site also has a search function.....use it to search for info you are looking for.....you can read how others solved a similar problem....most questions have been answered already many times before......(y)
Oillywater
I have the factory manual for the motor but says nothing about removing lower unit but I’ll just search it up thanks
