Force 125 Anyone recognize this part?
TheWitz
I found this part lying at the bottom of the engine compartment. Can't determine what it came off of. Similar in color to the carbs. The squared off section and the handle indicates some leverage is involved. Thanks.Force125Part2.jpgForce125Part1.jpg
TheWitz
Why is it deleted? I saw on the rules a mention of photo upload tutorial. However, when I click to view, I get permission denied. I did reduce the size of the images, were they still too big? Thanks.
roscoe
roscoe
Your photos are fine.
The no permission message was just because you were new to the forums.
Cyclops222 message was deleted for some reason.
But, unfortunately I can’t identify the part for you. Could be a manual choke lever.
jerryjerry05
Pic showed up just fine.
The part?? No idea :(
What were you working on that you found that part??
TheWitz
From lack of use, the motor is not running well at idle. Smooth for a few seconds, then stumbles for a few seconds, the pattern repeats itself. I think I'm dealing with a fuel delivery issue to one of the carbs, most likely the upper one. When priming, I noticed fuel leakage at the coupling, so I ordered new o-rings for that. I also saw someone comment that the fuel diaphragm should be replaced periodically, so I ordered that too. With the cover off, I happened to see this part laying at the bottom of the compartment, below the carbs. No clue what it is or where it fell off from.
