findinghomer
- Joined
- Nov 7, 2009
- 378
well my engine some times idles very roughs and shuts off. i wanted to rule out compression so i ran test. all cylinders were 126-130. however in my clymer manual it says should be 140-160 psi. is this a sign of engine problems?
now on to the rough idle, i believe its a carb problem? bowl is overflowing with fuel after it runs a few minutes, also my spark plugs were fouled wet, and black. it seems im running really rich. will carb rebuild fix this? if so what all should i replace? thanx in advance
