Greetings! Great forum and great advice all around!!
Here's my problem..
I have a 1988 Force 125 on a 19' Bayliner Capri Cuddy. I've done alot of work on it and still have problems.
Since I have owned it (I have had it on the water 4 times so far) I cannot seem to get to full RPM (it is pretty consistant at around 3000 RMP) and run at slow speeds (Between 10 and 20 mph).
I've done all the work below, changed loading of the boat, changed props, and I cannot seem to get it to move as it should (Though, it runs much smoother now!)
The stats are as follows:
Compression on all cylinders is ~150.
I have spark on all 4 cylinders.
I have fuel to both carbs and have adjusted floats to spec. (though, I do get a little fuel "drool" from the carb intakes)
Work Done:
-Replaced impeller.
-Crimped new terminals on end of plug wires. (The old ones were corroded and actually rusting off the wires).
-Removed, cleaned, and adjusted carbs per spec.
-Timed motor on water at WOT.
-Fixed exhaust "Boot" (was leaking exhaust into cowl).
-Set all linkage per spec. (Throttle plates open at WOT etc..)
-Checked for slipping prop hub as recommended on the forum.
-Set idle mixture to proper spec.
I'm at wit's end, its embarrasing to see a little aluminum fishing boat running laps around me!
Any advice would be great!!
Here's my problem..
Work Done:
-Replaced impeller.
