Is this the right position of the impeller thank.
cuenta Petty Officer 2nd Class Joined Apr 26, 2011 Messages 137 Nov 2, 2012 #1 Is this the right position of the impeller thank.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,931 Nov 2, 2012 #2 Re: Force 125 help looks correct to me. The fins will point counterclockwise when you flip the housing over to install it.
cuenta Petty Officer 2nd Class Joined Apr 26, 2011 Messages 137 Nov 2, 2012 #3 Re: Force 125 help thank roscoe
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 18,196 Nov 3, 2012 #4 Re: Force 125 help It doesn't matter which way they are pointing. Once it starts to run they will go to the right direction on their own.J
J Jiggz Captain Joined Oct 23, 2009 Messages 3,909 Nov 3, 2012 #5 Re: Force 125 help jerryjerry05 said: It doesn't matter which way they are pointing. Once it starts to run they will go to the right direction on their own.J Click to expand... The manual recommends starting in the right direction as rotating in opposite direction caused cracks on the fins even for brand new ones. Of course, the possibility of cracking a new one is a lot less than an old one.
O oxmax360 Seaman Joined Sep 10, 2012 Messages 61 Nov 4, 2012 #7 Re: Force 125 help Also love that old school spark tester in the background of the pic, where did you find that one?
cuenta Petty Officer 2nd Class Joined Apr 26, 2011 Messages 137 Nov 4, 2012 #8 Re: Force 125 help the spark plug test i buy in harbor freight tool florida
