redfury
- Joined
- Jul 16, 2006
- 2,657
So, end of the season, brought the family on the boat, had a gunshot like backfire that destroyed the rubber exhaust boot. Couldn't get the engine to run without the hood off, and it didn't run that great. Used the trolling motor. Brought it back out and it ran, but a bit rough, I could hit 38 mph with it, which is pretty normal, but the engine would run up the rpms and then drop them and surge. Actually had the engine quit for a moment like I had forgotten to open the vent on the fuel tank...started right up and kept running. Last time out, had a terrible time keeping it idling, would die when put into gear. Midrange cruising seemed pretty smooth, but it would still surge, just not as much during WOT.
So, I put it in my tank of water, with muffs and water from the hose ( seems to be the closest I can get to lake pressure ) and checked spark. I was getting spark on all cylinders, very strong snapping arc. However, I did a cylinder balance test and found the 3rd cylinder down from the top didn't change the operation, so I am running on 3 cylinders. A compression test showed pretty equal pressure in each cylinder ( my starter is needing replacement, so I couldn't get really good cranking readings. So, I figured that I might have a reed problem, since the lower carb was dirty with fuel/oil residue. Well, I pulled the carbs and reed valves out and they all physically appear perfect. I didn't see any distortion, any cracks. I did see milky oil in the passage just inside the block, but I can't be 100% certain of a bad head gasket as I had the cover off the engine and it had rained 2 nights before. I had the covers off the front of the carbs, though I suspect not much moisture would get in that way, particularly since the motor was trimmed up for trailering.
It had been running great prior to the backfire ( literally like a gun...scared everyone half to death ). I was able to troll for quite some time without any hesitation or loading, changing gears was smooth and never had an issue with the engine quitting. Something happened during that backfire and I can only suspect the head gasket at this point, but before I drop $40 on the gasket, I hoped to gleam some insight here first...perhaps a few nods in that direction , or something else I can check before I commit to replacing that gasket. I have photos on my phone that I can upload if there is anything you want to see.
