SkiDad
Thread starter- Joined
- Jul 18, 2010
- 1,518
I picked up a turning point prop that uses a hub kit. Got a new TP hub kit 501 (mercury) - The thrust washer taper is different than my current thrust washer. I seems to fit ok but when I tighten it kinda gets stuck to the prop shaft b/c it's not tappered the same. Prop fits good and no slop.
any issues running it this way or should I use my old thrust washer - if I use it I think i need to sand the top of the washer down about 1/16 so it sits flush on the back of the prop. Right now it hits the plastic insert and not fully hitting the prop metal.
This hub kit washer looks the same as the one I saw on the michigan kits.
