Re: Force 125 Trim Bleeds/ Lifts slowly
The shuttle valve only has the o-ring in the center. Remove the 2 o-rings from valve use a blunt tool in o-ring groove to remove steel cap/plug from valve, if cap hard to remove soak in hot water, inside valve is spring and needle,seal is on end of needle. remove remains of old seal install new seal. New seal has bevel on inside dia, this bevel goes toward the needle.<br />Part number for seal is Mercury pn 820719. The sears number I had is not a good number. If you cannot find seals, I have 2, they cost me about 4.00 each.
