navigator336
- Joined
- Jul 27, 2003
- 270
I have a 1987 Force 15 HP with coils and points ignition system. The engine is very low hours, but sat for about 5 years. Engine starts and idles fine (after cleaning the carb). It will rev up fine but then quickly lose revs (in neutral or in gear). I cleaned the carb and checked the fuel pump strainer. The plugs are new. I cleaned up the points, but they are still pitted. I gapped them to about .018" not knowing what they're supposed to be at. I suspect the points and possibly a bad coil that can't fully saturate at higher rpms. I hate to change it on a hunch as they cost about $80.00. Anything I'm overlooking? Maybe a bad fuel pump?
