Force 1986 85hp
Landen_33
The engine starts once and once I try to start it again it will not start. Any suggestions on what to do?
jerryjerry05
Do a compression and then a spark test(check each cylinder) post the results.
You using the fast idle in the shifter?
Starting procedures? A tiny bit of starting fluid won't hurt.
The Force power
If I may add; Make sure you are cranking the engine with a TESTED GOOD battery! a weak battery will not spin fast enough to produce enough electricity to create spark.
