Force 35hp, Compression check
ceast71112
Had a serious overheating problem, melted the wires from the power pack. repaired the wiring, Pulled a plug and checked for spark, had a spark, engine will not start, Backfires once in a while when cranking. compression check shows 50 on each cyl. Whats a good reading supposed to be?
Charlie
Barnacle_Bill
Re: Force 35hp, Compression check
If those readings are accurate, you have serious problems. You might want to verify it by using a different gauge. Over heating could have very well ruined the cylinders.
jerryjerry05
Comp should be 140-150# Tilt it up and put Marvel Mystery oil in both cylinders let it set for a week(keep checking and keep it full).This might free up the rings. You probably roached the motor and need to rebuild.Jerry
ceast71112
Ok I will try a different gage, then the oil thing.
Thanks for the quick reply
Charlie
