Force 50 (84) wiring help needed!
OzzmysterG
I hope someone can help. I have a SECOR manual, and it shows how the wiring should be for the starter relay, but somehow mine won't work - so I was hoping someone could look at theirs and let me know how theirs is wired. Here goes: POS connects to starter relay - other side power to the starter. I have a yellow wire that goes back to the control box on the back. In the manual, it shows that the NEG from the resistor should be hooked up with the black ground from the console to the same side as the starter POS side of the starter relay. The only problem is that my connectors have too small of a hole to fit. Can anyone help? Thanks in advance.<br /><br />Ozz
OzzmysterG
Re: Force 50 (84) wiring help needed!
Lonewolf -<br /><br />Got your pic, thanks - what manual is that from, looks a lot better than mine. Will let you know how it works tonight.<br /><br />Ozz
