chillin014
Thread starter- Joined
- Jan 14, 2009
- 91
I am replacing some things on this old motor and today's project was both ignition coils. Well the new CDI coils aren't exactly the same. The old coils had ground wires coming from them and then another wire with connectors from the CD box.
Before I try to describe anything here is a picture of the new coil.
As you can see in the picture there is a screw and connector already under the screw. Is this where I should be connecting the wire from the CD box? The instructions suck but it sounds like that is what I am to do "cut off primary lead, strip, crimp and solder terminal to it". I am completely competent in wiring I just need to clarify I'm making the right connection.
So my next question is, what about the ground?? Is it self grounded/already grounded? There is a thin piece of metal which wraps around the top of the coil going from the bracket to a nut on the other side which you can not see in the picture much but it is on the left side wrapping around the coil on the opposite side from the one facing the camera.
Thats it for now I suppose...just dont want to make any mistakes. Thanks!
