jwall116
Thread starter- Joined
- Sep 4, 2015
- 97
Hello iboats!
New to the forums and as a boat owner. I recently purchased a 1986 Bayliner Capri with a Force 50.
I have ordered the manual for the engine, and just waiting on it to arrive. So I would like to ask these questions prior to tearing into the engine.
The problem I have is two parts,
1) In neutral, if i blip the throttle it revs up as normal but during the decel will buck and shake as if it's only running on 1 cylnder/ When it is doing this, it will not return to normal idle for some time.
2) While in no wake zones, rpms are just above idle it will be fine at low rpms and high but at a certain rpm.. lets call it 1500-2000 range it blurbles by means of dipping in rpm. A slight raise or lowering of rpms puts me in the <1500 rpm or +2000rpm.
Does this sound like a timing issue? I have replaced the plug, they were black, and full of oil (previous owner ran it at 40:1.... YES he was an old man stuck in his ways)
Fuel is marina 87 gas, Oil is Penz semi Synthetic @ 50:1
I am not new to 2 strokes, but brand new to marine 2 strokes.
Also the boat is only getting 25mph via gps. The engine sounds good at full throttle, however I was expecting around 28mph with just me in the boat.
Any insight would be highly appreciated!!
