force 50hp will crank but wont start.
snakedoc
I'm new to this forum stuff, hope i do it right. I have just bought a old bassboat that has a 50hp force on it. i put on new fuel lines new sparkplugs new battery and fuel tank the motor will turn over but wont fire i have fuel at the carb, spark and 120 psi comp. i dont know what year it is i cant find any #on the motor.i'm not new to boats but this one s got me stumped. any help whould be app. thanx snakedoc
gunner1
Re: force 50hp will crank but wont start.
Are you choking the motor when trying to start it? On some models you push the key in while cranking. Since you've checked all the things you need for combustion, maybe this is your culprit. Unless your timing is off...
JB
Go to the Engine FAQs Forum snakedoc. Do "Outboard won't start".
Let us know what you find..
snakedoc
I did try to chock the motor with no luck, where do i find this engine FAQs Forum. I looked at your photos gunner1, it looks like a fun project.
mikes 86
you should check your kill switch, if it is engaged it will not let any spark to the motor. that was my problem, mine was located right under the forward and reverse lever i had to pull mine out and wedge small piece of wood to hold it in place. if that doesn't work check motor for spark. good luck.
tony4pyro
I had a similar problem with mine a while back and upon inspection I found out that the choke was not adjusted correctly and was not closing all the way. These motors need a good siphon to get the flow of gas started, and once I got it to close all the way, it fired right up. I am no expert, but maybe this helps.
