Re: Force 70 heavy start up
BTW, the pics show the most likely cause of the rings failing is they got caught with one of the exhaust ports. If you haven't done so, highly recommend chamfering all port holes (intakes and exhaust) before re-assembly. You can do this with a small file or better yet with a small grinder like a Dremel tool with a conical grinding stone. The critical chamferring is in the vertical portions of the port holes. It doesn't have to be a large chamfer maybe around 1/16.
