Skydiver Scott
Thread starter- Joined
- Aug 3, 2009
- 25
I have a new to me 1987 Capri Bow Rider with the Force 85. The engine runs great and had a great time at the lake this last weekend. The question I have is regarding the Transom mount and the engine tilt. There is not an electric tilt/trim but instead I set the trim with a bar when I lower the engine. I have to lower the motor by taking out what I call the UP HOLD bar (pic included) then I put in the trim bar where I choose and lower and lock the engine. Looking at this engine mount there is a small bracket on the right side and corresponding holes to have another bracket on the left that I would assume would have a notch to hold the engine up (not transporting strong but going up and down the ramp to the water strong) This would be great so I can put the engine down in the water from in the boat and not back down the ramp with the bottom of the engine with very little clearance..
I don't know if this makes any sense but hopefully it will..
Also my single shifter controller is "touchy" it has a release button I am guessing and I find a difficulty in moving from fwd to rev even with a pause. There must be some trick to make it work but I am not sure. The release button maybe after a pause in Neutral to prevent engaging too quickly from fwd or Rev with rpm's? any thoughts would be great or the controller might be not working so well and I can get a new single shifter controller for about $150 I see on line..
Your thoughts are appreciated
Scott C.
Scott C.
