Zack Of All Trades
Thread starter- Joined
- Jul 11, 2021
- 41
Hi guys, this is my first post here and I want to say this has been the most helpful forum out there with my bayliner project.
I have worked on this motor for a while and it ran okay, I was dealing with some fuel supply issues which i fixed. however the other day I was adjusting throttle etc... to gain top end speed as i was maxing at 18mph and I took it out and had difficulty shifting, initialy it would shift if i ram it into full throttle and would go about 22mph before i decided to slow down because i didnt trust it.
Now it won't shift into forward at all from the control box it would just clunk but if i put the control box slightly in forward and shift it from gear case it would go into forward no problems.
but if i take out of gear and try to go into forward again it wont go into it.
reverse works fine every time.
I also replaced the throttle cable, adjusted the linkage tab per the manual and neutral is properly centered. but that last 1/2 in push to get it into forward doesn't happen. even when engine is off.
Please help me as I wanna get out on the water this weekend
Much love!!
Much love!!
