Hi,<br />I know this sounds similar to other topics on here, so just want to ask a few BRIEF questions regarding my FORCE 85hp 1987 outboard, model no: 856x7b serial no: 4132 on a Bayliner Capri Bowrider.<br /><br />I have a similar problems to others:<br /><br />1) The engine starts fine when cold at dock and normally when warm in the ocean. Problem is when I engage forward or reverse gears slowly, the engine stalls. I have to full throttle then try n back off, to get the boat to go slow. Works about 2 outta 5 times, tis a PAIN, and makes mooring a NIGHTMARE. Also, if I try to restart the engine too many times in a row, then it floods the carbs and I have to wait ages to restart, although it always does restart after drainage and a few mins rest !<br />2) <br />SO could this be the CARB settings ?? Do I have to do the usual ½ turn to 1 ½ turn clockwise / anti clockwise to set my carbs ?? Have seen a few comments already. <br />2) Could my linkages to loose, therefore not making it engage gear / idle too well, although when running in neutral it idles perfect.<br /><br />Have bought some QuickSilver Power Tune spray for the carbs and some QuickSilver Fuel System additive, to will try those this wkend to see it it helps.<br />By t way, im running on Unleaded 95 petrol with 2-stroke outboard oil at 50:1 ratio.<br /><br />PPS: WHY DO FORCE ENGINES ALWAYS SEEM TO HAVE THE SAME PROBLEMS !!! ??????
