Force 85HP 85 Want start
Alroddy
Getting fire to silinoid. (New) Can not hear choke activate with switch pushed. voltage to switch. Battery charged. Clean terminals. Fuse ok. Netural start switch ok.
Skiwi
Re: Force 85HP 85 Want start
More info needed, does it turn over but not fire or does it just click or nothing at all happens?, does the primer get hard?, is there fuel in the carbs etc.
Questions with not much detail tend to get less answers, help us to help you by providing more details of the symptoms and what you already checked and tried.
Alroddy
No click. Want turnover. Nothing.
my1stboat1
THE WORD IS WON'T TURN OVER NOT WANT.... sorry ... its was bothering me to read it ...
Check voltage at the starting selenoid coming from the battery, then have someone put the key in the crank position and check for voltage coming out of the selenoid to the starter. Then check to make sure all the grounds are clean and tight. And put a breaker bar on the flywheel nut and see if the engine turns manually...
SweeperForce
If your getting power to the soleniod, but no power to the starter, the only thing else I can think of is: make sure the circuit breaker switch is pushed in.
Tom
