Force 90 alarm
Russdog
I just bought a Spectrum Fish & Ski with a Force 90. Several times shortly after starting it up an alarm goes off (high pitched alarm). The previous owner said that it was the over heat alarm, however I am running water through the engine. Can anyone he me understand what it may be? The two times it occurred (2 O/O 4) it went off when what seemed to be touching some wires under the dash.
Thanks,
Russdog
jerryjerry05
Re: Force 90 alarm
It sounds like you have a loose wire bad connections.At the outside a bad sender(not likley) but possible.
If running on land you might not have enough water thru the system. Jerry
