Force 90 engine removal
Russdog
I have an older model Force 90 and need to remove it in order to do a transom replacement. Does anyone know if there is a eye hook that can be put on it in order to pick up the engine? If not is there a recommended approach to take?
Frank Acampora
Re: Force 90 engine removal
Easiest thing to do is take a plate and drill three holes in it same as top of flywheel. Drill center hole for an eyebolt.
If you have friends, the engine is only about 275. 2 1/2 men can lift it off.
