Force 90hp
TW1011
Can someone help me with doing a compression test.. I got a compression tester and I took all the spark plugs out and screwed in the compression tester and tried turning over the motor to get a reading and the compression tester wasnt doing anything really. I read that you need to unplug the ignition coil, does this matter and if so how do I go about unplugging that??
