roscoe
- Joined
- Oct 30, 2002
- 21,916
I've got a '95 Force 70 hp with the external tilt and trim pump, the one that uses motor oil and is filled with the engine lowered. It has no manual release. <br /><br />If I should have a leak or line break, the motor should lower down, right? And I might be able to manually raise it up to get it on the trailer. <br /><br />But if I were to have a motor or other electrical failure, the motor would be locked where it stopped.<br /><br />My question is, is there any way, other than removing a line to relieve the pressure, to get the motor up or down, in the case of an electrical failure?
