Force Outboard Maintenance and gauges
eavdic
Hi got 1991 Force, I have a manual but does not indicate all the grease points I need to adress anyone know where I need to add grease ...Thank you .Also what gauges except from speedometer can I add to my bayliner capri with this force motor, I wanted to buy the kit form here it has rpm, water pressure, etc...anyone have any suggestions.
Thank You
jason32038
Re: Force Outboard Maintenance and gauges
Don't buy a kit because the tachometer will most likely not work right on your engine. Find out how many poles your stator has...if it's 20 then you need to buy the proper tachometer first then buy the other guages individually and hopefully you can find guages that match.
eavdic
Hi Jason, thank you very much,
I have a tachometer now, which works. I just wondered if I could get RPM and water pressure or oil gauge installed. I wondered if anyone had them installed on their force if possible to do so.
I will double check on the stator, manual should have it.
jason32038
You'd save yourself some time if you just look under the flywheel and count them. I don't even think the manual would specify that.
