force outboard or I/O engines use same powerhead?
Jasper8301
Can anyone tell me if the 1991 Force 120 Hp. I/O Powerhead is the same as a regular outboard powerhead ? Mine: I/O is the L-Drive model and is completely trashed and I want to replace it. Thanks, John
Bifflefan
Re: force outboard or I/O engines
Can anyone tell me if the 1991 Force 120 Hp. I/O Powerhead is the same as the regular outboard powerhead ? Mine: The I/O is the 'L' model is completely trashed and I want to replace it. Thanks, John
Isnt Force an OB?
IO is inboard outboard.
Whats a regular outboard?
Jasper8301
my Bayliner Capri is pwerd by a Force 120 Hp Inboard /Outboard L drive and the only powerheads I've found are for Force outboards , So are they the same powerhead on both?
Frank Acampora
Re: force outboard or I/O engines use same powerhead?
The powerhead mounting pattern and just about everything else is the same. However: I have it from an old reputable Chrysler dealer and mechanic that the crankshaft is balanced differently in the L Drive powerhead.
Best I can say is buy an old, cheap, running powerhead (85-125) and try it.
pnwboat
Check the splines on the crankshaft where the drive shaft to the lower units connects. Some of the L-Drives used a drive shaft that has 13 splines. Most of the power heads for the regular outboards were 15 splines.
Jasper8301
Thanks guys, your post have greatly appreciate3d and helpful, any additional info is appreciated as well,
