cuenta
- Joined
- Apr 26, 2011
- 137
I hope this thread helps them to learn
how test our electrical system before buying a expensive part
I hope the experts in force outboard to give us advice
I give my contribution to test the ignition coil..
**primary test**
multimeter in function of ohm..(Ω)
black lead to ground (black wire)
red lead to primary wire
this has to give 0.2 to 1.0 Ω
**secondary test**
multimeter in function of ohm..(kΩ)
black lead to primary wire
red lead to spark plug wire inside the boot
this has to give 800 to 1100 ohm..(kΩ)
in some 85hp model is only 160 to 200 ohm..(kΩ) some black coil
someone knows how to test
1) stator
2) trigger
3)cdi ignition pack
4)rectifier
**primary test**
**secondary test**
1) stator
2) trigger
3)cdi ignition pack
4)rectifier
