Force prop
forceproblem
Re: Force prop
There are ally of 15 inch diameter props out there used for sale I know that doesn't fit just want to know how much room I have
labawg
Re: Force prop
I went and measured mine(1984 125 hp ) and I would say 14" is the maximum safe size if you could somehow make a different manufacturer propeller fit. I really doubt it would be worth the effort though and most likely the prop will strike the exhaust snout.
steelespike
Re: Force prop
Extreme increase in diameter will lower rpm which likely will require a reduction in pitch
and a reduction in speed.Then there is the gearcase /hub relationship to deal with.
steelespike
Re: Force prop
If you tell us what you would like to accomplish we may be able to help.
forceproblem
Re: Force prop
Not really trying to accomplish much really my aluminum prop is fine but I want to replace it w a stainless I am just limited on options for buying used. Seems everyone has a 15 inch diameter and that it to big for my motor. I was just wanting to know how much room I had for choices that would fit well with my 125 force
Frank Acampora
Re: Force prop
It's not the size of the blades that limits you, it is the hub diameter. The gearcase on Force engines is only 4 inches and only Force props OR small gearcase Mercury props will fit--unless you want to do some modifications.
Yeah, if you research and look at prop stock/part numbers on replacable hub props, you will find some Honda-Yammy-Suzy props might fit. But here, you need to do your homework.
Unless you are willing to do modifications, stick with the 13 1/4 inch diameter props. Your Force really won't like other sizes.
forceproblem
Re: Force prop
Well then thanks for the info I had no idea that it was that involved I will have to look closely at what I buy then thank u
