I have a single tilt trim ram system that is off a 40 hp Force.
1. Is this cylinder the same as any Mercury? The Force part number is F749381F. Is there a rebuild kit for it? If not are all the o rings and seals standard sizes?
2. Is the pump itself the same as any of the Mercury? Is it a good or crappy pump?
3. Is ATF the preferred fluid for this system?
4. Does this SINGLE ram function as both a trim and a tilt? Can it be trimmed at high speed or does it not have the "power" for that?
Thanks!
Thanks!
