force tilt & trim owners
my1stboat1
I have an 1988 85 hp force..... I was just curious does the tilt/trim setup on our forces have a limiter on raising the engine too far when under a load or on plain..... I was out playing around the other day and noticed if i hold the trim switch up while on plane the engine will never trim completely out of the water but as soon as i nuetral the boat out and stop moving the tilt/trim works perfect... Is this how our system operates based on psi against the outboard cause theres no trim limit switches on my unit except power and ground.....
RRitt
Re: force tilt & trim owners
the small ram has valves that pop open if you try to go faster than idle.
snowman48047
Yes it will only trim so far when under way.
