grant_boat
Thread starter- Joined
- Jul 16, 2007
- 1
I need assistance with my recently purchased boat. it has an 85 HP FORCE outboard engine. On the first try, it starts and will run good but will not exceed 10 MPH when it should be able to go somewhere around 50. I think the engine isn't getting enough gas. Maybe the choke on the key start is messed up, or something in the engine is stuck and won't release enough fuel. I ran it for about a 1/2 hour, but once we turned it off and started it up again it stalled once put into gear. I was able to eventually inch it forward so it wouldn't stall (thank god we didn't get stuck on the lake). This is what made me get the idea that fuel is not passing properly to the engine...like there is a choke problem or the carburetor isn't opening up. When I took the cover off and manually pulled on the pin that controls the throttle I could really rev it up (in neutral). But it just won't do it in gear by itself, it almost always stalls once put into gear
it has compression. The carburetor was just rebuilt. new sparks. Gas tank is venting
Any help?
Any help?
