Ford 302 - 188 hp mercrusier
mccurtis
I am thinking about buying a Starcraft Chieftain with a Ford 302 V8, 188 hp.
Does anyone know if this is a good reliable motor that parts are readily available for? I would appreciate your comments, pros and cons.
Thanks - MC
Re: Ford 302 - 188 hp mercrusier
Ayuh,... Merc hasn't used a Ford since the late 70s....
I'd look for Merc/ Chevy power
Beefer
Is there really a 188hp V8? That sounds like a really small V8. I have a 3.7 inline 4 that puts out 188hp. ??
Fordiesel69
Its a good motor for sure, and was reliable, but finding parts is going to be a bear. To retrofit to a chevy/merc you will have to gut the compartment and swap all the stuff.
The boat would have to be near mint, and in perfect running order before I would touch it. Volvo used that engine into the 90's but most parts do not swap with mercruiser.
Icyharp
It is a good motor, I have one that I pulled from my Lund that never gave me a problem. Other than valve cover gaskets all has been good. As for other parts I have never needed anything, but having a pops that is in the marine buisness I was never worried either.
mccurtis
Thanks for all your imput. I think I will pass on buying the boat. - MC.
Hi MC,... ezmobee told me the back-story on your dilemma,....
The 188 is a 2bbl. carbed version of the Ford 302 motor which is quite a common motor....
It's easy enough to find parts for(internal hard parts), but they tend to be slightly more expensive than a Chevy motor...
The exhaust manifolds are abit of a problem, but if yer boating in Freshwater, they should last a lifetime, so long as they don't freeze, 'n bust...
They tend to be considerably more expensive than those for a Chevy, but Osco still carries 'em...
For the longer boat, 'n what yer lookin' to do with it,...
It should serve you well...;)
mccurtis
Thanks - Bond-o
I am thinking I may wait to find a 24" chieftain that has a chey motor.
mccurtis
I talked with a marine engine rebuilder today and he told me the 302 is a good motor and that all parts, internal andexternal, are readily available. So, I may go for the boat however, its a total redo
mkast
How much does this boat weigh?
mccurtis
Approximatly 2900 lbs.
