Ford 302 188hp to GM 305 - 350
CaptMick
I am curious to know if a Ford 302 is "swapable" with a GM 305 or 350 using the existing transom assembly and outdrive.
Boomyal
Re: Ford 302 188hp to GM 305 - 350
I'm not Merc expert but you'd at least probably need a different intermediate housing to mate with the different motor. The transom opening would have to be determined with relative motor mount dimensions etc. Some Merc Guru out here has probably checked this out before.
Everything Forward of the Inner Transom Plate would need to be replaced....
CaptMick
Is the inner plate the same plate that the steering attaches to?
Yes,<br />The Steering attaches there,+ the Rear Motor Mounts.....
