Check/adjust timing, ensure carburetor is clean/adjusted/jetted properly, ensure fuel pump pressure is correct at all RPMs/under loadSo what's the fix
I got snooping around in there and I found the vaccume port bottom of carb were pcv line runs was really loose. Not only the hose but the brass fitting as well
Good catch, that is a direct vacuum leak and would cause a lean issueFuel pump..carb...all new..everything
According to my Merc manual, 888 and 215 (both use the Ford 302 engine) should be running ACDelco CR83T, Motorcraft BTF-3M or Autolite 124 for earlier heads (18mm plugs) and ACDelco MR43T, Motorcraft ARF-3 or Autolite 145 for the later heads (14mm plugs)...The plugs that came with the boat are autolite 123. Is this the appropriate plug or should I change them. Carborated...petronix ignition...
I'm not sure what yellow clear hose you are talking about. I do know that off my pump should be a hose yes. I am talking about hose from valve cover pcv to carb base was looseGood catch, that is a direct vacuum leak and would cause a lean issue
It's great you have new fuel system components however you must ensure they are correct for your engine and properly adjusted. Again, have you checked/adjusted the timing? Would guess idle timing for your engine is 10 degrees BTDC
They are 18mm plugs...so in your opinion what's the best plug..
Personally, I use NGK... For your engine, that would be NGK AR6FS.According to my Merc manual, 888 and 215 (both use the Ford 302 engine) should be running ACDelco CR83T, Motorcraft BTF-3M or Autolite 124 for earlier heads (18mm plugs)
Chris.......
Yeah, that was my misreading of your post regarding the vacuum line at the carburetor base. Thought I read fuel pump vacuum line (which does not exist) and thought of the diaphragm rupture safety hose.I'm not sure what yellow clear hose you are talking about. I do know that off my pump should be a hose yes. I am talking about hose from valve cover pcv to carb base was loose
Vaccume gauge reading about 17/18Alright put fresh plugs in...timing still at 10 btdc...I've reset carb and got it as close as I can...how much.of a run on these plugs before I check colours
