15-25 more hp. You need an intake, carb, fuel line and throttle bracket mods.I'm thinking of changing intake and carb to 4 barrel...pros and.cons...aside from fuel mileage.
'888' was a 188hp 2bbl 302....I think the 302 ford came in both versions from Merc so you can look up what HP would be with both.
one BOAT unitLol...well for theb1000 dollars it will cost me...I will imagine the...waaaaaaa
Yeah if you hadnt just put a new engine in i would suggest a 351…Lol...well for theb1000 dollars it will cost me...I will imagine the...waaaaaaa
Yeah i did the same when i repowered six years ago.I thought of that however to late...I'm sure this will do me good I don't really ever go to far...half hour max runs to my fishing spots.
That's only like ½ now with inflationone BOAT unit
Parts and upgrades are much cheaper if you're not in a hurryI do like the boat for sure...I hope I get some years out of this engine before I need to redo this...it's been a learning curve alright
Well over 30 years. I have a friend with a boat with a couple of 1984 Mercruiser '260's in it... They run ok...Curious what the life expectancy is for inboard engine if maintained.
Fresh or salt water? Change the oil and lube a 1500 -plus hours should be no big deal. You may run into the issue with MC-1 parts becoming obsolete, drive can be replaced with R/MR/Alpha gen 1 as a bolt in but trim/trnasom housing may be an issueCurious what the life expectancy is for inboard engine if maintained.
As Chris mentioned make sure to maintain your exhaust (if you have a half system) and or elbows (full system) to keep water out of the cylinders ...Mostly salt...I have closed cooling and I flush the engine well.
