- Joined
- Mar 8, 2009
- 43,923
Member @Jakem has a 1975 Ford 289 with closed cooling. The short of the story is its not plumbed like it should and does not have a bypass hole in the thermostat housing. Without the bypass there is not enough flow.
https://forums.iboats.com/threads/overheating.745111/
Need a housing that will fit a Ford SB intake, have at least 3 ports (1coolant in, 2 coolant out to manifolds) and a bypass port
@Scott Danforth
I'm looking at the 351 and most things are NLA. Wonder if a GM will fit
This is the one used for open cooling but would need to close off a port or two
https://www.marineengineparts.com/exhaust-cooling/thermostats-housings/mercruiser-ford-engines
@Scott Danforth
