Ford Coil Pack Connection
agallant80
Replaced the coil packs on the V10 Excursion. The clips that connected the ignition wire were brittle and a few of them broke off. Any ideas on how to keep them in place? Engine keeps on vibrating a connection loose because of the missing clip causing misfires. I am sure that im not the only one who has had this issue.
matt167
Re: Ford Coil Pack Connection
You can buy new clip parts from the parts counter for cheap.. The plastic case will pull away from the copper conductor parts and that's akk you need to replace.
MTboatguy
Heavy duty, heat and UV resistant zip ties is what I am using.
