Brock.Ward
- Joined
- Jul 1, 2010
- 148
Hey guys, got another boat, project boat. Its a 1975 Slickcraft 235. Has Ford/Mercruiser 233HP 351 v8. Traded it for a generator cause it has the plastic/fiberglass flooring and the interior was in pretty dang good shape. I took out plugs which look fairly new, turned the crank with a leverage bar and it turns so its not froze up. The key was hanging out wired but i dont think it is wired correctly, and when i turn it it just clicks the engine solenoid i believe. Tried to hook up my jump box to starter direct and it just clunks or clicks once. Here are my questions before I put more work into this thing. Can you look over the wires and make sure the key is hooked up correctly along with the coil resistor next to distributor? Please let me know thoughts or questions, i'll get right back to you! Thanks!
