Re: Ford V8 saga gets underway
He just has the machine work done at a engine build shop and replaces the long block with one that is already built and uses your block as a core to go back to the builder. It is quicker for him and probably cheaper. He does not have to by the equipment to bore out the block, turn the crank, etc. That is pretty standard practice for most shops. <br /><br />What you should (in my opinion) is find a builder who can do marine engines. Remove your endine and strip it down to the long block. Take the long block assy. to him. Let him tear it down and reduild it. Then build it back to complete engine and reinstall.<br /><br />It will take a little longer(maybe a week or so)but you will know all the parts match up when you go back together.<br /><br />If he has a prebuilt 302 marine long block that you knew was compatable with you flywheel and balancer then it would be fine to exchange. But you have to sure that it uses the same balance.<br /><br />On a car I could help you out but with a marine 302 I am little help. <br /><br />Again, I feel your best bet would be to have your engine rebuilt by a reputable engine builder who knows marine engines. That way parts interchangeability (is that a word) is not an issue.<br /><br />BTW, I have worked on Ford engines at dealerships or my own shop for over 15 years.<br /><br />Good Luck,<br />Sean
