Re: Forget everything you heard about prepaid cell phone service!!
Ok I'll try to answer some of the questions posed since my last reply.
No, straight talk doesn't mind if you stream anything like pandora (very light data usage) or movies, just when you hit 2.5gb for the month they will throttle you. This doesn't mean CUT YOU OFF, it means slow you down. The only thing you can't do is use the phone as a wi fi hot spot.
Someone said "I can't do this because I really need my phone" Um, I really need mine to. I was a manager of a corporate jet hangar and would receive flight alerts and flight info from pilots via text and cell calls. I never missed a lick. Now I use it at my new job. It's not substandard service, it uses the same networks and towers.
Net 10, Tracfone and Straight talk are NOT the same. They might all be prepaid, and straight talk even owned by Tracfone, but they aren't the same service. ST and TF can't even use the same phones.
If you have ST and on your phone it shows ATT, you are on that network. You're not going to get "worse" coverage than someone who is subscribed through ATT, you're using the same towers, same everything. So if ATT is strong in your area, you can drop your ATT contract and get ST with ATT service and you're back on the same towers at half the cost.
