Forgot the Plug!
Linc33
Well I took my turn on this one this past Friday.<br /><br />Took the day off (Summer Fever sick day) and took the family to the lake for the day.<br /><br />Prepped the boat in the parking lot doing all the usual stuff and somehow forgot the drain plug that I keep hung from the steering wheel.<br /><br />Tied the boat to the launch pier had the wife sit near it with the kids while I parked the van, paid then filled out the launch fee envelope, walked the launch dash card back to the van, double checked the van was locked etc. etc. etc. I am including these boring details to give you a sense of how long the water was gushing into the boat.<br /><br />Finally got back down to the pier (lake was nice and deserted, nice to go out when most others are at work) and begin to get in and my wife and me notice at the same time that there's water in the boat 1/2 way up the lounge seat base!<br /><br />I grab the plug, jump back to the back of the boat, pull out the 6 gallon tank to access the bung and place plug in its' proper location.<br /><br />I then remember learning (probably here) that if you get your boat on plane and remove the plug, the water will exit the boat. I tried this. I wouldn't suggest it. It was a little nerve racking. I had to really try to get the boat on plane. I put it at WOT got into the bow and tried to weigh it down enough to get it on plan. Well it finally got on plane. Then I had to crawl back to the back of the boat, maneuver around the floating gas tanks and remove the plug. All the while praying I don't sink, or hit anything as no one was steering at this point. (Darwin award candidate? Me?)<br /><br />I made a circle around the lake like this and noticed the water level lowering *somewhat* but at least I wasn't sinking.<br /><br />I then decided to do what I should have done in the first place which was put the boat back on the trailer and pull it up a bit on the ramp and let 'er drain.<br /><br />This I did, and about 10 -15 minutes later, the boat was empty. Luckily there was no ramp traffic at all while I was draining, but the small crowd at the adjacent beach had a good little laugh at our expense. But by that time we were laughing too.<br /><br />Once we got all that behind us, we motored out found a great spot on the sand bar and spent nearly 5 great hours on the water. Turned out to be a GREAT day.<br /><br />Thought I'd share this so others could share the "I forgot the plug" shame.<br /><br />*Hopefully* this'll be the first/last time for me on this one.<br /><br />-Linc
QC
Re: Forgot the Plug!
Dude, like wow, what about your bilge pump?
ziggy
linc. don't feel lonely. i'm sure many of us have forgot the plug. at least once. i have, only once though, :) . but ya do learn quickly about things like that. anyways, my comment is that i don't think ya need to be on plane to get the water out. just moveing fwd enough that there is low pressue behind ya. the water will then siphone out with the plug pulled. cool that ya had a great day boating. things have a way of working out.....sometimes......
tommays
you have now joined the club with one of the largest memberships in the world :D <br /><br />there are those who have or those that will forget the plug ;) <br /><br />tommays
18rabbit
Linc, you do know you are the only person in the whole world that has ever don something like that, right?<br /> :D <br /><br />Ok, maybe not...and if you ask if I have ever done that, I'm taking the 5th...ain't sayin' no more about this.<br /> :cool:
18rabbit
Oops! Double post...and that doesn't mean I did it twice!!!<br /> :)
baja power
Im with quiet cat.. didnt your Bilge pump kick in? or could it not keep up?
Linc33
Thanks for the replies and encouraging words.<br /><br />Realgun - SHT? I don't know that one...<br /><br />Quite Cat / baja power - I don't have a bilge pump installed. The boat is a 1974 vintage, came original with nav lights, horn, tach and speedo, but no bilge pump. That is on my "projects I need to do" list.<br /><br />-Linc
ptrau
I have invented a small device that will let you know that your plug is not installed when you turn your ignition on. I am installing one on my boat this weekend and will let you know how it works.<br /><br />Is one of these available on the market now? That way I could stop stop tinkering and start boating.
seseattle
I just installed a one-way plug mount. I found it at Boaters World for $10 and quickly decided that was cheap insurance. The bronze fitting was an identical match to my existing fitting so swapping them took around 1 minute. It has a floating captive ball inside the fitting so that water can only flow out of the boat (in theory). It's not a 100% solution, but if I ever forget to put the plug in (again) it should severly limit the amount of water coming in.<br /><br />Scott
txswinner
Banned
Careful seseattle, a friend had a float plug and only problem was it did not always drain well and transom rot set in.
aspeck
SHT - "Stupid Human Tricks". Got a bunch of these "plug stories" there. My own from last December is there - difference is while getting boat on plane and water drained the throttle cable froze at wide open. I had the tow vehicle keys in my pocket ... too crazy a story to relive, but I did live, that is the important thing! Join the club, there are a bunch of us members.
