Forgot to Fog motor
fmalott
i winterized motor and outdrive drained water and antifreezed outdrive (yea i know some of you don't use antifreeze air don't freeze) i forgot to fog the motor i don't want to start the motor again will it be just ok to pull plugs and spray into each cylinder will this be ok enough or do i need to start motor again and spray in to carb
Re: Forgot to Fog motor
Ayuh,... That'll be just Fine,... I don't fog at all...
fmalott
i take it fogging just keeps cylinders from rust so just pulling plugs ok then
Bluestream
Fogging coats the valves, the intake, and cylinders. oil in the plugs does the cylinders only. You'll be fine
capecodder116
Wouldn't worry....I'd take the spark plugs out, spray some mystery oil in the cylinders, turn the engine over by hand...reinstall the spark plugs and tuck her in for the winter.
fmalott
just finished doing that THANKS guys
