Re: Forktail, help with choice of kicker.
BillP, rusting valvetrains simply aren't an issue with owning a 4-stroke. For the most part, the valvetrain components are sealed from the environment. If your valves and springs have rusted in just 3-4 months, you have a major problem.<br /><br />If this was a common problem, we'd all be hearing about it, or experiencing it. That's just not the case.<br /><br />On the other hand, a 2-stroke is exposed to the environment much more. Via the always-open intake and exhaust ports, the metal reed valves, piston, rings, connecting rod, etc, are directly exposed. Unlike a 4-stroke, there are no valves to close out the environment from the crankcase. <br /><br />We've all seen rusted reeds and the ring of rust on the cylinder wall that a 2-stroke is famous for. This is one of the reasons 2-strokes require "fogging". Fogging is not recommended for any of my 4-strokes. <br /><br />If you've got environmental rust in your 4-stroke, you'd have it worse in your 2-stroke.<br /><br />But if you'd rather troll with a 8 HP 2-stroke over a 8 HP 4-stroke (that runs like a Swiss watch), then be my guest.
