- Joined
- Mar 8, 2009
- 44,793
Started the install of the engine, it takes a lot of chain pulling to pick it up high enough
Tried to install and it was not going in, need two shoe horns.:facepalm: Took it back out and repositioned the straps to put the engine at an angle tipping to the rear. This helped but still no go. :facepalm: So removed the seawater pump and alternator.
Managed to get it in and put everything back on including the new elbows. Most of this was done laying on top the motor hanging upside down. :brick: Don't know if I'm getting better or just getting use to the pain. Made a bracket to hold my lube bottle and go figure the hose is not long enough. This one is no issue, the hose is cheap and readily available
And now for the rest of the story, there seems to always be something else. My new exhaust elbows are 9 inches from the transom and about 1.5 inches high and to the right or the hole. Now I need about 12 to 13 inches of flexible exhaust hose. Seem no one has the Shields or Trident 252 of 252V (silicone) 4 inch hose. All backorder 2 to 3 weeks. Starting to think about a 4 inch pipe (copper or stainless) and 2 of my 4 inch boots.
Anyone have any other ideas?
Also had to remove the bar used to raise/lower my engine hatch because the elbows will interfere with it. now have to make something up to use the drive of maybe remove it. Don't think this will be a big thing but for now on the back burner
