Formula 330 Cabin Floor & Ceiling Work
tpenfield
Progress update . . .
I cut the vinyl plank floor for the top step in the cabin. . .
The rubber trim strips that I ordered came today as well. - Stair nosing and carpet edge . . . both black. So, I'm good to go.
Next steps are to apply adhesive to the top step and 'glue' the planks down. Then I can start working on the planks for the main cabin floor.
tpenfield
More progress . . .
I got the cabin floor 'planked'. So, just waiting for it to set up for a few days and then I'll be doing the carpet along the sides and the edging.
This all worked out the way I hoped it would (so far). Now just have to see if I can bend the stair nosing (rubber) around the curved stair.
tpenfield
I got the stair nosing installed. I had to really heat/stretch it around the corners.
Next steps will be the carpet transition strips on the cabin floor, then carpeting on the sidewall.
Any thoughts on the adhesive for the carpeting :noidea:
I am not sure what Formula used. My thoughts are either a general purpose carpet adhesive or a contact cement. Any other ideas that would be good for a marine environment? I got lots of vinyl tile adhesive, but probably not the right thing for carpet. :noidea:
chevymaher
I did massive research when it was time for mine. I was on all the forums. I used this glue. I got caught in a downpour that put a foot of water in the bilge in less than 10 minutes. Carpet was running water wet.
My carpet is never ever coming out. It is good stuff and the price is right. 24 hours to full cure.
It has my version of the woodenglass approval.
Edit I got the pail with the handle larger but this is the same stuff.
https://www.lowes.com/pd/TEC-Skill-S...B&gclsrc=aw.ds
AShipShow
I've had weird results with DAP Weldwood for different projects... It may work great for carpeting, but I used it to veneer the glovebox on my previous boat, and let it setup for like a week, and then the first day on the water sitting in the sun, it wrinkled up and was ruined...
tpenfield
I ended up getting what the local big-box store had . . . "Roberts 6700 indoor/Outdoor Carpet Adhesive".
Also got some of the Weldwood Contact Cement for the transition strips along with some 3/4" and 1" 18-Gauge crown staples for the nailer gun to tack down the carpet and the transition strips.
froggy1150
Ensign
Do a test and walk on it. Read somewhere that someone put some down and walked on it days later and the glue came thru. Also after cure soak it and and try again to make sure it don't get soft. That's one of those things that would suck to do twice
tpenfield
I've been walking & standing on it a lot, because where else am I going to stand within the cabin :noidea: . Yes, some of the glue does come through as the planks settle in, but it is easily cleaned up. It is probably going to take a few weeks for the glue to really set up.
The nice thing is that when I nail the carpet edge down around the perimeter of the floor, it will lock the planks in place so they can't go anywhere. Such is the case now with the step area, because of the stair edging.
the adhesive takes a few weeks to cure when under a non-porous material, which is why madprops had an issue with his dash.
under carpet, it cures in 2 days because the VOC's can escape thru the carpet.
tpenfield
Finished the flooring and carpet and got everything buttoned up . . .
attachment.php
attachment.php
attachment.php
attachment.php
Now onto regular season prep work . . . :)
Ted, those of us not on the formula boats forum are seeing blank squares.
tpenfield
Rats . . . :( I'll see if I can post them elsewhere. Not sure what the deal is with the forum website, but the regular picture upload stuff has not been working for a week or so. The only way I could get anything in the way of pictures to post was to use the image icon on the format banner, which then only takes URL's, not uploads.
Ted, do you have them on your Blog? on tpenfield.com
tpenfield
[QUOT
E=Scott Danforth;n10862437]Ted, do you have them on your Blog? on tpenfield.com
[/QUOTE]
Not yet . .
Does this work?
kcassells
Well how come those pics showed? Secret back door in?
Does look good!
Jesus now I can't even post comments on my build.
tpenfield
It seems that if I reference an image from a website (like my blog site tpenfield.com) using the image insert icon ( the one on the format editor), then the images will post. If you use the paper clip icon, they won't/don't. One of the recent changes to the forum site must have busted the paper clip feature. Anywho . . .
I updated my blog site, so here are some images from that site.
This was an OK exercise for me . . . finding the 'back door' to posting images, since I re-visited my blog site, which I had not done in a while, and made sure I can still login, update things, etc.
