- Joined
- Jul 18, 2011
- 18,866
Hi Folks:
I have been 'monitoring' high levels of moisture in the main bulkhead of my Formula 330SS over the past year, as documented in this thread that I started at the time >>> Link: http://forums.iboats.com/boat-restor...ds-584200.html
Despite my efforts, the moisture levels have not come down all that much, since the boat is stored outside over the winter months. So I decided to remove and replace the bulkhead. This is a project, that I would have been hard-pressed to do last year, since the boat was 'new-to-me'. Having familiarized myself with the boat's structure over the past year, I felt that I could now take this on, and seeing as the moisture levels remain fairly high, it is probably best to replace the bulkhead, rather than let the problem fester.
Using what I call my 1990's CAD system, I was able to make an illustration of the boat's hull & structure. Using these drawings, I have planned out the process.
Here is the hull of my boat. . . the main bulkhead is in Blue and the stringers are in green.
The area of high moisture (and presumably the source of the problem), is the orange hashed area.
I plan to cut out the center section of this bulkhead out to the point where it meets the main stringers that surround the fuel tank.
This will expose the rear portion of the fuel bay, where I plan to remove/replace some of the foam that holds the fuel tank, to provide a working area. This will also let me inspect the rear face of the tank, etc.
There is a cross member (yellow) that I plan to leave in place. Then, I will fabricate a new section of bulkhead and replace it.
So, that's "the plan" . . .
Yesterday (Sunday) was 'cutting day'. I figured that I would cut out the bulkhead before winter really sets in and let it sit over the winter, finishing it off in the spring (like April/May).
* * * continued on the next post * * *
